Connecting to the NVIDIA Omniverse collaboration platform
Tool
Tool set
Omniverse Connector
(Windows only)
Visualization
Vectorworks provides Windows users options for connection to the NVIDIA® Omniverse™ collaboration platform. With the Omniverse Connector tool, you can establish a live session with other Omniverse users or publish a 3D model to the Omniverse Nucleus server to be opened, viewed, and modified by other Omniverse users. You can also export the current model to USD Composer or USD Presenter, to open it on your local machine.
Use of the NVIDIA Omniverse collaborative environment requires an NVIDIA RTX® video card with the latest video drivers, an Omniverse account, an installed Omniverse Nucleus server and account, and an installed version of the USD Composer and/or USD Presenter applications.
As an alternative to using the Omniverse Connector tool to interact with the Omniverse collaborative platform, the Export USD (3D only) command exports 3D models in .usd, .usda, and .usdc file formats (see Exporting USD files). The Import USD (3D only) command imports .usd, .usda, .usdc, and .usdz file formats (see Importing USD files).
Mode
Description
Publish to Omniverse
Exports the current model to the Omniverse Nucleus server for use by others; see Publishing to Omniverse
Send to Omniverse
Exports the current model to a location on your local machine and opens it in the selected version of USD Composer or USD Presenter; see Sending a model to Omniverse locally
Live
Creates or connects to an existing Omniverse Live Session associated with the current model; see Connecting to an Omniverse Live Session
Preferences
Opens the Omniverse Connector Preferences dialog box to set default export parameters; see Omniverse Connector preferences
Real-time rendering synchronization
