Creating linear material details
Mode |
Tool |
Tool set |
Modes for Creating polylines |
Linear Material
Detailing |
The Linear Material tool draws a standard representation of sheet building materials (such as plywood, gypsum board, and stucco) along a path. To create linear material details, either use the Linear Material tool, or draw a polyline and then select the Create Objects from Shapes command (see Creating objects from shapes).
To draw linear material details:
Click the tool and mode, and if desired set the linear material attributes from the Attributes palette (fill style, pen style, and line thickness). The linear material attributes can also be specified after creation.
Click to set the object's start point.
Click to set the end of the segment and the beginning of the next. Continue drawing segments in this manner until the object is complete.
Click a second time at the start point to complete a closed polyline object, or double-click to complete an open polyline object.
The first time you use the tool in a file, a properties dialog box opens. Set the default parameters. The parameters can be edited later from the Object Info palette.
Parameter |
Description |
Offset |
Sets the distance of the object baseline from the drawn path |
Type |
Select the kind of linear material to draw; available parameters depend on the type of linear material selected |
Board (generic) |
Creates two polyline edges; the space between the edges can be specified with a fill color from the Attributes palette
Gyp. Bd. (detail) |
Creates a board object with an additional offset line and fills the space with a stipple pattern
Plaster/Stucco |
Draws an irregular top line for the object
Plaster/Stucco (detail) |
Draws an irregular top line for the object, and fills the space with a stipple pattern
Plywood/OSB |
Creates a board object with evenly spaced parallel lines
Plywood/OSB (detail) |
Creates a plywood object with additional diagonal slashes
Built-up Roof |
Draws a filled band over a coarse, oval-shaped stipple pattern
Corrugated Deck |
Draws a zig-zag deck pattern
Corrugated Deck w/fill |
Creates a corrugated deck and fills the depth of the deck
Corrugated Deck w/fill (detail) |
Creates a corrugated deck, fills the depth of the deck, and adds a stipple pattern
Thickness |
Specifies the thickness of the linear material; for plaster/stucco details, specifies the average thickness of the linear material |
Pitch |
For corrugated deck details, determines the corrugation spacing |
Corrugation Depth |
For corrugated deck details, determines the corrugation height |
Closure |
Specifies which sections of the linear material object should have a closed end (does not apply to Built-up Roof details) |
Density |
For details with stipple patterns, sets the stipple density |
Variation Length |
For plaster/stucco details, specifies (world-based) the maximum length of the outer surface line segments |
Variation Thickness |
For plaster/stucco details, specifies (world-based) how much the outer surface line thickness varies from the thickness of the linear material |
Vertex parameters |
Edits the linear detail path vertices; see Editing vertex-based objects |
Linear material details with stipple patterns may require a significant amount of time to draw.
Create a plug-in symbol from a linear material object (see Creating symbol definitions) with Convert to Plug-in Object selected. Activate the symbol in the Resource Manager to draw the linear material detail with the saved symbol parameters.
