Round tubing
Mode |
Tool |
Tool set |
Modes for The Symbol Insertion tool |
Round Tubing
Detailing |
The Round Tubing tool and Round Tubing - 3D tool share the same position on the tool set. Click and hold the mouse on the visible tool to open the pop-out tools list (see Pop-out tools) and select the desired tool.
To create round tubing:
Click the tool and mode.
Click to place the object in the drawing, and click again to set the rotation. The first time you use the tool in a file, a properties dialog box opens. Set the default parameters. The parameters can be edited later from the Object Info palette.
Parameter |
Description |
Series |
Select the desired series to display the appropriate nominal sizes |
Size |
Select the round tubing size |
Length (Design Suite product required) |
Enter the length of the 3D round tubing |
Draw Center Lines |
Select whether to draw the 2D round tubing with center lines |
Place Locus at Centroid |
Select whether to draw a locus at the centroid of the 2D round tubing |
Custom Size |
Select this option to enable fields for specifying a custom round tubing size |
Outside Diameter |
Displays the outside diameter of the tubing, or if Custom Size is selected, allows entry of a custom value |
Wall Thickness |
Displays the wall thickness of the tubing, or if Custom Size is selected, allows entry of a custom value |
Section Properties |
Section properties are automatically calculated and displayed based on inch units for imperial shapes and millimeter units for metric shapes (regardless of the units selected and Show Unit Mark setting in the Units dialog box) |
Area |
Displays the round tubing area |
About Axis X-X/Y-Y |
Moment of Inertia |
Displays the moment of inertia about both the horizontal (X-X) and vertical (Y-Y) centroidal axes |
Section Modulus |
Displays the section modulus about both the horizontal (X-X) and vertical (Y-Y) centroidal axes |
Radius of Gyration |
Displays the radius of gyration about both the horizontal (X-X) and vertical (Y-Y) centroidal axes |
