Square tubing
Mode
Tool
Tool set
Square Tubing
Detailing
The Square Tubing tool and Square Tubing - 3D tool share the same position on the tool set. Click and hold the mouse on the visible tool to open the pop-out tools list (see Pop-out tools) and select the desired tool.
To create square tubing:
Click the tool and mode.
Click to place the object in the drawing, and click again to set the rotation. The first time you use the tool in a file, a properties dialog box opens. Set the default parameters. The parameters can be edited later from the Object Info palette.
Parameter
Description
Series
Select the desired series to display the appropriate nominal sizes
Size
Select the square tubing size
Length
(Design Suite product required)
Enter the length of the 3D square tubing
Place Locus at Centroid
Select whether to draw a locus at the centroid of the 2D square tubing
Draw Center Lines
Select whether to draw the 2D square tubing with center lines
Custom Size
Select this option to enable fields for specifying a custom square tubing size
Width
Displays the width of the tubing, or if Custom Size is selected, allows entry of a custom value
Wall Thickness
Displays the wall thickness of the tubing, or if Custom Size is selected, allows entry of a custom value
Inside Fillet R.
Displays the inside fillet radius value of the tubing, or if Custom Size is selected, allows entry of a custom value
Section Properties
Section properties are automatically calculated and displayed based on inch units for imperial shapes and millimeter units for metric shapes (regardless of the units selected and Show Unit Mark setting in the Units dialog box)
Area
Displays the square tubing area
About Axis X-X/Y-Y
Moment of Inertia
Displays the moment of inertia about both the horizontal (X-X) and vertical (Y-Y) centroidal axes
Section Modulus
Displays the section modulus about both the horizontal (X-X) and vertical (Y-Y) centroidal axes
Radius of Gyration
Displays the radius of gyration about both the horizontal (X-X) and vertical (Y-Y) centroidal axes
Structural shapes and details
