Design SuiteZ-Section
Mode
Tool
Tool set
Z-Section
Detailing
The Z-Section tool and Z-Section - 3D tool share the same position on the tool set. Click and hold the mouse on the visible tool to open the pop-out tools list (see Pop-out tools) and select the desired tool.
To create a Z-section object:
Click the tool and mode.
Click to place the object in the drawing, and click again to set the rotation. The first time you use the tool in a file, a properties dialog box opens. Set the default parameters. The parameters can be edited later from the Object Info palette.
Parameter
Description
Series
Select the desired series to display the appropriate nominal sizes
Size
Select the Z-section size
Length
(3D only)
Enter the length of the 3D Z-section
Place Locus at Centroid
(2D only)
Select whether to draw a locus at the centroid of the 2D Z-section
Lock Centroid Position
Locks the centroid position; when locked, the centroid behaves like the object’s insertion point and remains in position if the object’s shape/size/rotation is edited
Custom Size
Select this option to enable fields for specifying a custom Z-section size
Depth
Displays the depth between endpoints, or if Custom Size is selected, allows entry of a custom value
Flange Width (Top) / (Bottom)
Displays the top and bottom flange width, or if Custom Size is selected, allows entry of a custom value
Web Thickness
Displays the web thickness, or if Custom Size is selected, allows entry of a custom value
Flange Thickness
Displays the flange thickness, or if Custom Size is selected, allows entry of a custom value
Toe Radius (Top) / (Bottom)
Displays the top and bottom toe radius value, or if Custom Size is selected, allows entry of a custom value
Fillet Radius
Displays the fillet radius value, or if Custom Size is selected, allows entry of a custom value
Section Properties
Section properties are automatically calculated and displayed based on inch units for imperial shapes and millimeter for metric shapes (regardless of the units selected and Show Unit Mark setting in the Units dialog box)
Area
Displays the Z-section area
About Axis X-X/Y-Y
Moment of Inertia
Displays the moment of inertia about both the horizontal (X-X) and vertical (Y-Y) centroidal axes
Section Modulus
Displays the section modulus about both the horizontal (X-X) and vertical (Y-Y) centroidal axes
Radius of Gyration
Displays the radius of gyration about both the horizontal (X-X) and vertical (Y-Y) centroidal axes
Structural shapes and details
