Applying textures to objects and faces using the Texture tool
Tool
Tool set
Shortcut
Texture
Basic
Shift+T
The Texture tool allows you to place a texture directly on an entire object or on specific faces of an object. You can also use the tool to apply textures to components or parts of walls, slabs, roof faces, and roofs. The texture is applied with a single click on the highlighted object/face under the cursor, regardless of selection status. As textures are added or changed using the Texture tool, the changes display in the Render tab of the Object Info palette, where they can be managed; see Managing object textures from the Object Info palette.
You can also apply a texture from the Resource Manager. Select the object, and then right-click on the resource, and select Apply from the context menu or double-click the resource to activate it; the Texture tool is automatically activated.
Alternatively, drag the texture from the Resource Manager onto the object to apply it. To apply the texture only to a particular face, press the Ctrl key (Windows) or Cmd key (Mac) while dragging the texture to the face. To replace the matching texture on multiple faces, press the Ctrl+Shift keys (Windows) or Cmd+Shift keys (Mac) while dragging the texture to one of the faces with the texture to replace.
Additional settings and modifier keys affect the way a texture is applied to wall, slab, roof face, and roof components or parts; see Applying textures to walls, slabs, and roofs.
To manage textures applied to an object or to edit the mapping, use the Object Info palette's Render tab or the Attribute Mapping tool.
Mode
Description
Apply to Object
Applies the active texture to the clicked object
Apply to Face
Applies the active texture to the clicked face.
The texture mapping of each face depends on the Overall Map Type. If the Overall Map Type is not Perimeter, the faces receive the Surface UV Map Type. If the Overall Map Type is Perimeter, the faces receive the Perimeter Map Type.
Apply to Face mode can be temporarily invoked by pressing the Ctrl key (Windows) or Cmd key (Mac) while using any of the other modes.
Replace Matching Texture
Applies the active texture to all faces of an object that have the same texture as the clicked face.
Replace Matching Texture mode can be temporarily invoked by pressing the Ctrl+Shift keys (Windows) or Cmd+Shift keys (Mac) while using any of the other modes.
Pick Up
Picks up the texture on an object or face that is clicked on. After the texture is picked up, the tool immediately changes to the previously used mode.
Pick Up mode can be temporarily invoked by pressing the Alt key (Windows) or Option key (Mac) while using any of the other modes.
Texture
Opens the Resource Selector to select a texture; double-click the resource to activate it
Supported objects for the Texture tool
Apply to Object, Apply to Face, and Replace Matching Texture modes apply a texture to, and Pick Up mode picks up the texture from, the following objects and their faces:
Generic solids
3D primitive solids (sphere, hemisphere, cone)
Extrudes, multiple extrudes, tapered extrudes, and extrudes along path
Sweeps
CSG solids (add/subtract/intersect/section - Apply to Face, Replace Matching Texture, and Pick Up modes work only on objects created in Vectorworks 2020 or later)
Groups (only supported objects in groups can be textured; to use Apply to Face, Replace Matching Texture, and Pick Up modes, you must enter object editing mode)
3D symbols (only supported objects that make up the symbol can be textured; textures must be applied in object editing mode)
Apply to Object and Apply to Face modes also apply a texture to walls, slabs, roof faces, and roofs.
Apply to Object mode also applies a texture to the following objects:
3D polygons
Subdivisions (textures on subdivision objects do not display on the Object Info palette Render tab)
Some objects that use components/parts (such as hardscapes)
Some plug-in objects, depending how the object was made (when plug-in objects are texturable textures do not display on the Object Info palette Render tab)
Applying a texture with Apply to Object mode
Applying a texture with Apply to Face mode
Applying a texture with Replace Matching Texture mode
Textures on 3D objects
Textures on objects with components
Direct texture mapping
