Worksheet functions
Worksheet functions take an argument, perform an action, and return a value or values. For a complete list of functions and examples of how to use them, refer to the developer-oriented documentation here: Github.com/Vectorworks/developer-worksheets
If you're working with material resources (Design Suite product required), refer to MaterialProperty names and types to use in creating reports. See https://github.com/Vectorworks/developer-scripting/blob/main/Common/Tasks/Info/WorkingwithMaterials.md.
There are two basic types of functions: those that use the values you enter, and those that use information from objects in the drawing. The arguments required by the two function types are different.
Number or text arguments: Functions that begin with a lower case letter typically require a number value or a cell address as the argument. For example, the acos function returns the arccosine of the value that is specified in the function argument. The argument you enter can be a mathematical expression (such as 3/5), an address of a cell that contains a number (such as A12), or an actual number. The argument for all trigonometry functions must be in radians.
Criteria arguments: Functions that begin with a capital letter must be applied to one or more specific objects in the drawing. In a cell in a database header row, a function is automatically applied to the object listed in each sub-row, so no criteria argument is required.
However, in a spreadsheet cell, you must enter criteria to select the objects the function applies to. For example, the Area function returns the combined area of all 2D objects that meet the criteria. To specify which objects to obtain the area of, either use the Insert Criteria command from the Function menu (), or enter the criteria manually.
For details about how to specify criteria such as the object type, class, or visibility, see Github.com/Vectorworks/developer-worksheets/blob/main/Articles/SearchCriteriaFormat.
Formula syntax
The Criteria dialog box
