SpotlightInserting a television object
Mode
Tool
Tool set
Television
Audio/Video
The television object simulates CRT and flat screen televisions.
To identify which symbol was used to create a television object in the drawing, right-click on the television and select Locate Symbol in the Resource Manager from the context menu.
To insert a television:
Click the tool and the insertion modes.
Click to place the object in the drawing, and click again to set the rotation. The first time you use the tool in a file, a properties dialog box opens. Set the default parameters. The parameters can be edited later from the Object Info palette. Some information from parameters can also be placed on the drawing using the Text Options.
Parameter
Description
TV Type
Select the type of TV: flat panel, CRT, or CRT curved
Screen Aspect
Select the aspect ratio of the screen: 4:3 (Standard) or 16:9 (Wide screen); curved CRT screens cannot have a 16:9 aspect ratio
Casing
Displays the television casing
Select Casing
Select the television casing from the Resource Selector; available models depend on the selected TV Type and Screen Aspect
Brand
Specifies the television brand
Model
Specifies the television model
Size
Displays the television size
Width (image)
Displays the width of the screen image area
Height (image)
Displays the height of the screen image area
Tilt
Sets the tilt of the television in degrees; positive values tilt the television screen facing up, while negative values tilt the television screen facing down
Weight
Displays the weight of the television
Hanging Point
Select whether to use a top, middle, or bottom hanging point
Wattage
Enter the required wattage, for power consumption calculations and reporting
Show coverage zone
(2D only)
Indicates the viewing area based on the screen size; observers within the area should be able to see the screen
Settings
Zone Reference
Calculates the coverage zone based on screen width, height, or diagonal measurement
Max Horiz. Angle / Max. Vert. Angle
Indicates the maximum viewing angle of the screen horizontally and vertically, relative to dead-on
Viewing Height
Enter the height of the average viewer when watching (likely, a seated height)
Near Multiplier
Specifies the multiplier of the reference dimension to determine the extent of the near coverage zone
Far Multiplier
Specifies the multiplier of the reference dimension to determine the extent of the far coverage zone
Screen Image
Displays the name of the current screen image
Edit Screen Image
Opens the Edit Screen Image dialog box to select the image for screen display; see Assigning an image, video, or input
Adjustable Stand
For flat panel televisions, select a stand to add to the screen casing
Pole Height
Select a height measurement from the base of the stand to the bottom of the screen casing, or select Custom to enter a Custom Height
Casing Height
Specifies the height of the casing on the stand
Power and Signal Details
Circuit Number
Indicates the circuit number where the television is plugged in
Circuit Name
Specifies the name of the bundled circuit group
Source
Specifies the source information
Drive Line
Indicates information about the drive line feeding the signal to the television
Input
Specifies the input information
Frame Rate
Specifies the frame rate information
Resolution
Specifies the resolution
Location, Position, Unit, Purpose, Vendor, Cost, Note
Adds information which can be placed on the drawing or used for reporting
Text Options
Opens the Text Options dialog box, to enable the display and format the text of labels
Default Text Positions
Restores text labels to their default positions
Classes
Opens the Classes dialog box, to specify class naming for the various portions of the television. This allows portions of the television to be set to visible, grayed, or invisible.
Use the standard class, select a class from the list of classes present in the drawing, or create a new class. Select <Television Class> to place the television element in the same class as the television.
Class Prefix: Specifies an optional default root class naming standard for all television parts; click Assign Default Classes With Prefix to begin all television class names with the prefix, so that they are sorted together.
Assign Default Classes With Prefix: Sets the class names for all television elements to the standard, using the Class Prefix if there is one.
Television elements: For each portion of the television, specifies the class name standard; the class names shown here are applied to the elements.
Update
Updates the object when changes have been made to the Object Info palette parameters
Load Information
A television is considered a point load in Braceworks calculations; if the insertion point is on a rigging object, it is considered to be a load on that structure. Load information is used for Braceworks calculations and reports (Braceworks required).
Include in calculations
Includes the television in Braceworks calculations; deselect to exclude the television from participating in structural calculations
Load Group Name
The load category is always Video for video screen objects
Load ID
Enter a unique ID for the load for informational use in reports
Load Name
Identifies the object in load calculations
Total Weight
Enter the total weight of the object
Position
Displays the name of an associated rigging object, if the object is attached.
For methods to attach loads, see Making the attachment.
Equipment Subparts
Lists the subparts that make up the object. These subparts are counted and reported separately in equipment and inventory lists.
The parameters must be selected for display for this type of object in Spotlight preferences: Inventory pane.
Equipment Virtual Parts
Virtual parts are associated with an object and are reported in equipment and inventory lists, but do not display in the drawing. After adding virtual parts, they are listed in the Object Info palette.
Edit Virtual Parts
Opens the Virtual Parts dialog box to add virtual parts to the object; see Managing virtual parts and independent virtual parts
Assign Sources
Opens the Assign Sources dialog box to assign the object and its subparts and virtual parts to an inventory source; see Assigning equipment to an inventory
Formatting video screen object labels
Concept: Attaching loads to rigging objects
Locating a resource from the drawing
