LandmarkSpecifying the tree protection zone
A 2D tree protection zone (TPZ) can be set in the Object Info palette, Existing Tree Tool Preferences, or the Existing Tree Settings dialog box. This TPZ can be reshaped as described below.
In addition, a 3D TPZ can be created, which serves as a grade limit on site models, protecting the area around the tree from site model changes.
Creating a 2D tree protection zone
To specify the tree protection zone for one existing tree:
Select the type of Tree Protection Zone.
Parameter
Description
None
Does not display a tree protection zone
Display Circular Zone
Displays the tree protection zone as a circle around the tree trunk; set the circle radius with TPZ Radius
Display using 12x DBH
Displays a circular tree protection zone that is calculated based on 12 times the diameter at breast height (DBH) parameter
Shaping an existing 2D tree protection zone
A tree protection zone may need to extend beyond the initial boundary shape, or may be restricted by existing objects or buildings on the site.
When a TPZ is reshaped, the original calculated area is retained, and the area of the reshaped TPZ is displayed as the Adjusted TPZ Area in the Object Info palette. In general, you should ensure that the Adjusted TPZ Area matches the original calculated area.
To reshape the tree protection zone:
Select the existing tree.
Select Edit tree protection zone from the Object Info palette of a selected tree.
The tree protection zone displays with editing handles.
Drag the handles to reshape the zone. You can also adjust the radius at the corners of the zone with the TPZ Corner Radius value, which only displays during zone editing.
When reshaping is finished, deselect Edit tree protection zone.
Creating 3D tree protection zones
Command
Workspace: Path
Create 3D Tree Protection Zones
Design Suite: AEC > Existing Trees
Landmark: Landmark > Existing Trees
When working on a site model, it’s important to retain existing elevation around the existing trees. The tree protection zone is the area around the tree that should be fenced off, or preserved, to protect the tree. This command creates a copy of the 2D tree protection zone which acts as a 3D grade limit, protecting the tree or trees from adjacent site model elevation changes. The grade limit always applies to the existing site model. The 2D TPZ is part of the tree, but the 3D TPZ grade limit is not connected after creation.
You can create a tree protection zone around individual trees, or create a single zone around each group of selected trees with overlapping individual zones. An existing tree must have a visible 2D protection zone to create a 3D protection zone.
Select the desired trees.
Select the command.
The Create 3D Tree Protection Zones dialog box opens.
Choose whether to create individual 3D tree protection zones for each selected tree, or create a unified tree protection zone for each group of selected trees with overlapping individual zones. The TPZ Area displays the calculated area for the entire tree protection zone.
Adding existing trees
