Editing a title block border
There are two ways to edit title block borders: editing an existing object's parameters in the Object Info palette or Title Block Border Settings dialog box, and Editing a title block layout using object editing mode. Object editing mode for title block borders has extended capabilities that permit text objects to be linked to title block border data records so they update automatically as record data is changed; see Linking title block text to data records.
To create a custom title block, you may opt to begin with an existing style that closely resembles the title block needed, convert the object to unstyled, and then edit the parameters and layout.
Title block border properties
Most title block border parameters can be edited directly from the Object Info palette. To customize the parameters that display on the Shape tab, click Data Display Settings, and select the desired parameters, as described in the table below.
To edit all available title block border parameters from the Title Block Border Settings dialog box, do one of the following:
Click Title Block Border Settings from the Object Info palette.
Click Sheet Data or Project Data to open the Title Block Border Settings dialog box with that pane active.
Right-click the object and select Edit from the context menu (or double-click the object). From the Edit Title Block Border dialog box, click Settings and select the pane to edit.
Editing project-wide data from the Title Block Border Settings dialog box or the Object Info palette affects all title block borders in the file.
For title block borders using plug-in object styles, the parameters that are set by style display for informational purposes but cannot be edited from the Title Block Border Settings dialog box or the Object Info palette.
The title block border parameters are described in Title block border settings.
Title Block Manager
Double-click editing shortcut
