Creating arcs
The Arc tool, which creates circular arcs of any angle, has nine modes. The Push/Pull mode is available in 3D views for instantly extruding the arc after creation, and the Connect and Combine mode is available for use with the Tangent Radius and Tangent Locked modes.
The Arc tool and Quarter Arc tool share the same position on the Basic palette. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
Mode |
Description |
Radius
Defines the arc by its center |
Three Points
Defines the arc by clicking three points |
Tangent to Line
Defines the arc by defining a tangent to a line |
Center
Defines the arc by clicking two points and a center |
Specified Radius
Defines the arc by two points and a specified radius |
Point on Arc
Defines the arc by two end points and another point on the arc |
Arc Length
Defines the arc by the arc length and specified chord length |
Tangent Radius
Defines the arc by making it tangent to two selected arcs, circles, or lines based on a defined radius |
Tangent Locked
Defines the arc by making it tangent to two selected arcs, circles, or lines based on a locked intersection point |
Connect and Combine (available with Tangent Radius or Tangent Locked mode)
Used in conjunction with Tangent Radius or Tangent Locked mode; automatically connects two arcs by creating a third arc between them, then extends or trims the existing arcs before combining all three into one continuous arc |
Push/Pull (3D views only)
Instantly extrudes the arc after creation; see Push/Pull mode of planar tools |
Push/Pull Combine (available with Push/Pull mode)
When the shape to be extruded is drawn on the face of a solid object, combines the two objects into a single solid addition or solid subtraction; when this submode is disabled, the new extrude remains a separate object, and the existing solid object remains unchanged |
Either move the mouse to draw the arc or use the Data bar to enter an angle. Degrees start on the positive X axis (the "East" direction), and increase going counter-clockwise. ("East" is 0 degrees; "North" is 90 degrees; and "West" is 180 degrees.) To draw a quarter-circle arc beginning at 0 degrees and ending at the 6 o’clock position, enter -90 (minus 90) degrees. Enter 270 to draw an arc three-quarters of a circle around.
To create a NURBS curve, draw an arc and then select Modify > Convert > Convert to NURBS.
To edit an arc, click the middle handle with the Selection tool and drag to change the arc radius. Press the Option key (Mac) or Alt key (Windows) to change the arc’s size.
Arc by radius
Mode |
Tool |
Tool set |
Shortcut |
Radius
Arc
Basic |
3 |
To create an arc by its radius:
Click the tool and mode.
Click to set the center of the arc.
Click the start point of the arc. Move the cursor until the desired arc orientation and size are previewed.
Click to set the end point of the arc.
Arc by three points
Mode |
Tool |
Tool set |
Shortcut |
Three Points
Arc
Basic |
3 |
To create an arc by three points:
Click to set the start point of the arc.
Click to set the point for the arc to pass through. Move the cursor until the desired arc orientation and size is previewed.
Arc tangent to line
Mode |
Tool |
Tool set |
Shortcut |
Tangent to Line
Arc
Basic |
3 |
To create an arc by tangent:
Click to define the line to which the arc will be tangent. Move the cursor until the desired arc orientation and size is previewed.
Use tangent snapping to assist with drawing the arc tangent to geometry; see Snapping to a tangent (2D Only).
Arc by center
Mode |
Tool |
Tool set |
Shortcut |
Center
Arc
Basic |
3 |
To create an arc by two points and center:
As the cursor moves, the center of the arc is manipulated.
Click outside the arc to set the center.
Arc by specified radius
Mode |
Tool |
Tool set |
Shortcut |
Specified Radius
Arc
Basic |
3 |
To create an arc by two points and a specified radius:
The Arc Radius dialog box opens. Enter the length of the radius.
Arc by point on arc
Mode |
Tool |
Tool set |
Shortcut |
Point on Arc
Arc
Basic |
3 |
To create an arc by two end points and another point on the arc:
Move the cursor until the desired arc shape and size is previewed, and then click to set the arc. To constrain the angle of the line between the arc endpoints, press the Shift key when drawing the arc.
Without the Shift key, the angle of the line between the endpoints (clicks 1 and 2) is unconstrained, and the chord defining the arc height is an unconstrained line drawn from the second endpoint
When the Shift key is pressed, the angle of the line between the arc endpoints (clicks 1 and 2) is constrained, and the chord defining the arc height is perpendicular to the center of that line
Arc by arc length
Mode |
Tool |
Tool set |
Shortcut |
Arc Length
Arc
Basic |
3 |
To create an arc by arc length and chord length:
The Arc Length dialog box opens; set the parameters.
Parameter |
Description |
Arc Length |
The drawn arc length is displayed, and can be changed; this allows you to create several arcs with the same chord length and varying arc lengths |
Specify Chord Length |
Manually specifies the chord length, changing the arc endpoint |
Chord Length |
The chord length is the distance between the two end points of the arc; the arc length must be greater than the chord length |
Arc tangent by radius
Mode |
Tool |
Tool set |
Shortcut |
Tangent Radius
Arc
Basic |
3 |
To create an arc tangent by radius:
Do one of the following:
To trim or extend existing arcs and compose them with a third arc to create one new object, toggle Connect and Combine mode on.
To create a new arc, toggle Connect and Combine mode off.
Select the two arcs/circles/lines to which the new arc will be tangent.
When the second object is selected, a preview of possible tangent arcs displays where the cursor is currently located. The arc's size is controlled by the radius. Move the cursor, and then click to set the radius (or enter the radius in the floating data bar).
Move the cursor until the desired tangent arc displays, and then click the preview to set the arc. If the arc is created with Connect and Combine mode on, Tangent Radius and Tangent Locked modes can no longer be used on the new arc.
In this example, Connect and Combine mode is toggled on
Arc tangent by locked intersection point
Mode |
Tool |
Tool set |
Shortcut |
Tangent Locked
Arc
Basic |
3 |
To create an arc tangent by locked intersection point:
Click an exact point on the first arc/circle/line to lock the intersection point.
When the second arc/circle/line is selected, a preview of possible tangent arcs displays where the cursor is currently located. The second intersection point is determined by the radius. Move the cursor until the desired tangent arc displays, and then click the preview to set the arc. If the arc is created with Connect and Combine mode on, Tangent Radius and Tangent Locked modes can no longer be used on the new arc.
In this example, Connect and Combine mode is toggled off
