Architect or LandmarkCreating property lines with bearing and distance data
Mode
Tool
Tool set
Bearing and Distance
Property Line
Site Planning
To create property lines using the bearing and distance of each line segment:
Click the tool and mode.
Click to set the starting point of the first property line segment.
A red bull's-eye is placed on the drawing to mark the starting point; the Define Property Line dialog box opens.
Specify the segment parameters and click Add to update the drawing file. Continue to add or remove segments as needed.
Alternatively, for simpler, linear-only entry, click Preferences. From the object properties dialog box, click Simple Dialog on Bearing and Distance Mode. Now when you click to place the starting point, the Create Property Line dialog box opens. Enter the Azimuth and Distance for each segment, and select whether to close the shape automatically with the final selection.
Parameter
Description
Line
Select if the current segment is a line
Azimuth
Enter the azimuth or bearing of the line segment; if entering a bearing, a variety of formats are supported. Use spaces (N 10 30 0 E), degrees—d for degrees, m for minutes, and s for seconds (N10d0m0s E), or decimal degrees (N 10.5d 0m 0s E).
Distance
Enter the distance of the line segment
Curve
Select if the current segment is a curve
Start Tangent to Previous
Forces the back tangent to be collinear with the previous segment
Back Tangent
Enter the azimuth of the back tangent of this curve; a variety of formats are supported. Use spaces (10 30 0), degrees—d for degrees, m for minutes, and s for seconds (10d0m0s), or decimal degrees (10.5d 0m 0s).
Radius
Enter the radius of the curve segment
Arc Dist
Uses the distance along the arc
Chord Dist
Uses the distance between the point of tangency and the point of curvature
Tangent Dist
Uses the distance from the end point of the last segment to the point of the intersection of the curve
Delta Angle
Uses the central angle of the curve as measured from the center of the arc
Chord Bear.
Uses the bearing of the arc chord
Forward Tangent
Displays the forward tangent value
Counter-Clockwise
Draws the curve Counter-Clockwise
Remove
Click to remove the selected segment from the property line
Update
Click to update the parameters for the current segment
Add
Click to add a segment to the property line
< Previous / Next >
Click to move backward and forward through the segments
Automatically create closing segment
Automatically creates the final segment between the last point and the first
The first time you use the tool in a file, a properties dialog box opens. Set the default parameters (see Property line parameters). The parameters can be edited later from the Object Info palette.
