Help system features
Searching the topics
To search the topics, click the Search button Search help icon and then enter text in the Search box at the top of the help window. The search engine accounts for misspellings and uses autocomplete technology to make suggestions as you type.
When entering search text, use quotation marks to find a specific text string. For example, the search "standard views" (in quotes) finds topics that contain the exact term standard views. Searching without the quotes finds instances of both words together as well as each word individually. The search is not case-sensitive.
Press Enter to search the help system.
While searching, the progress is displayed under the Search box. When the search is complete, the number of results displays. If no results are found, "No results found" displays.
If the search is progressing slowly or appears frozen at 0%, connection or bandwidth issues may be impeding the search progress. The Session pane of the Vectorworks preferences allows switching to the local version of the help in this situation.
Search help
The search results list the topics that contain the search text or string. Topics are listed in order of relevance. For context, each result displays the topic heading, an excerpt from the text, and the breadcrumbs.
Click on a search result to open the associated topic; occurrences of the search term are highlighted. To remove the highlighting, click Remove Highlight  in the right panel.
Click the X at the right of the Search box to clear the current search terms and any search results.
Favorites
Favorites buttonTo view the saved articles in your favorites list, click Favorites from the Tool bar.
The Favorites panel opens, displaying a list of articles in the order in which they were bookmarked. Click a topic to view the contents. To remove a topic from your favorites list, click Edit Favorites Edit Favorites button, and then click Remove Remove favorites button next to the topic to remove. Close the Favorites panel to hide the saved articles.
List of favorites
To mark the active topic as a favorite for future reference, when the Favorites panel is closed, click Set as Favorite from the right panel. The icon changes to filled, indicating that the topic has been added to your favorites list.
Printing topics
Print button To print the currently displayed topic, click Print from the right panel (desktop view only). Use this button rather than the browser's Print command for best results.
Printing from certain browsers with the Print button may crop the help contents. If this happens, try using a different browser.
Related topics
At the end of certain topics, a list of additional topics with information related to the current topic is displayed. Click one of the topics to view the additional information. To return to the original topic, use the browser's Back button.
Related topics
Cross-references
Cross-references located within a topic are bold and highlighted with a teal color. Click these links to navigate to more information about the highlighted topic. To return to the original topic, click the browser's Back button.
Cross reference link
Browse navigation
The browse sequence buttons allow you to scroll through the help topics. These special navigation buttons display at the bottom of the topic window. Click Previous and Next to navigate through the topics.
Browse help
Go to top Click Go to Top to return to the top of a long topic.
To expand the central help panel, click Hide/Show Left Panel  to toggle the panel with the table of contents, commands/tools list, and glossary on and off, or Full Screen   to toggle both the left and right panels on and off.
Help feedback form
As you use the online help system to inform yourself about the commands and tools of the Vectorworks program, you may wish to make a suggestion or report a problem. A link displays at the end of every topic in the online help. Click the link to access an online help feedback page. Internet access is required to open the page.
Help feedback example
Movies
The Vectorworks YouTube channel contains video technical tips with an audio/visual explanation of various concepts. If a topic in the help has a related video tip, click on the Play button to watch the movie, or click Watch on YouTube. Internet access is required.
YouTube videos aren't always updated when there are minor changes to major features. If the video is still substantially correct and useful for learning about the feature, it remains in help even if some details have changed.
Parameter tables
The parameters of every dialog box are described in tables. By default, these tables are hidden so that you can read the steps of a procedure easily first. To view or hide a parameter table, click the link, Click to show/hide the parameters. This link toggles the table display on and off.
When you open a topic from the search tab, the tables that contain search terms display automatically.
You can easily toggle the display of all of the tables in a topic from the buttons on the Tool bar. Click Expand tables button Expand Tables to open all tables, and click Collapse tables button Collapse Tables to close them all.
Vectorworks website
Website button Click the website button to easily navigate to the Vectorworks website.
AI Assistant
 Click the AI Assistant button to open the Vectorworks AI Assistant in a web browser.
Commands and tools list
The Commands/Tools tab provides a filterable, alphabetical list of all the commands and tools in the Vectorworks program. Click on a command or tool name to view the associated documentation. The command and tool names can be filtered by entering a term in Find Keyword.
Glossary
The Glossary tab displays an alphabetical listing of frequently encountered terms in the Vectorworks program. Scroll to the term of interest and click it to view its definition. The glossary definitions can be filtered by entering a term in Find Term.
help glossary
