Editing wall features
The original 2D or 3D object from which a wall feature was created can be edited using standard editing tools. For example, the location or shape of the object can be changed.
To edit a wall feature:
Do one of the following:
Double-click the wall feature.
Right-click the wall feature, and select Edit from the context menu.
Object editing mode opens (see Object editing mode).
In object editing mode, select the object used to create the wall feature.
Edit the object as desired using 2D and 3D object editing tools, or delete the object to remove the wall feature.
The object's location can be changed, but it must overlap the wall.
Click Exit Wall Feature to exit the editing mode.
