Replacing
Slab StylesSlab styles applied to existing slabs can be replaced with a different slab style.
A slab replacement situation may also occur if pasting a styled slab from another file.
To replace a slab style:
1. Select one or more slabs.
2. From the Object Info palette, select Replace from the Style list.
The Slab Replacement dialog box opens. Specify the new slab style. The red line indicates the datum component of each slab style; replacement is aligned to the datum.
If slabs with different slab styles were selected for replacement, the current slab preview is blank and components do not display.
3. Click OK to replace the slab style of the selected slab(s).
