The Remove Wall Breaks tool cleans up any wall breaks or gaps that were created during editing. For example, when creating a new wall that joins an existing wall, if the new wall is later deleted, a break in the remaining wall displays at the joint. The Remove Wall Breaks tool can remove the break and any end caps.
To remove wall breaks:
1. Click the Remove Wall Breaks tool from the appropriate tool set.:
● Fundamentals workspace: Walls tool set
● Design Series workspaces: Building Shell tool set
Alternatively, right-click (Windows) or Ctrl-click (Mac) on the wall and select Remove Break from the context menu.
2. Click and drag to create a marquee box around the wall break or end cap to remove.
The wall break or end cap is automatically removed.
