Use the Reshape tool in a view other than Top/Plan to edit the wall height, change the elevation of wall peaks, add vertices to create peaks in a wall, and delete vertices that have been added. Use the Selection tool to change the wall length. Symbols remain where placed when a wall is reshaped.
In the following situations, the Reshape tool displays 2D Reshape modes; the vertices at either end of the wall can be moved, to change the wall length and/or location. See 2D Reshape Modes.
● In Top/Plan view
● When multiple walls are selected
● When a wall and other objects are selected
● When a marquee has been drawn
In any 3D view, when only a single wall is selected, the Reshape tool has three modes available.
Mode |
Description |
Reshape 3D Walls |
Adjusts the position of a selected wall vertex |
Add 3D Wall Peaks |
Adds a vertex to a wall for reshaping purposes |
Delete 3D Wall Peaks |
Deletes a wall vertex |
Walls can also be trimmed using the Trim tool; see Trim Tool.
