DesignSeries00126.pngEditing Detail Bubbles
Detail Bubble Properties
Edit the detail bubble properties from the Object Info palette.
Once the detail bubble has been placed, its marker can be selected from the Attributes palette (see Marker Attributes).
Editing Detail Bubble Record Information
To edit the record information associated with a detail bubble:
  1. Select the bubble, and then click Change Bubble Info from the Object Info palette.
  2. The Edit Detail Bubble dialog box opens.
  3. Enter the information associated with the detail bubble. The information can be used to complete the parts list and bill of materials worksheets.
  4. Click OK to return to the Object Info palette. If the Item # was changed, the change is automatically made to the Object Info palette and the object.
Creating Detail Bubbles
Marker Attributes
vectorworks.net
