DesignSeries00062.pngRivets
Large Rivets
To insert a large rivet:
  1. Click the Large Rivet tool from the Fasteners tool set.
  2. Click to place the object in the drawing, and click again to set the rotation.
Small Rivets
Rivets (DIN)
Tubular Rivets
vectorworks.net
