DesignSeries00070.pngSmall Rivets
To insert a small rivet:
  1. Click the Small Rivet tool from the Fasteners tool set.
  2. Click to place the object in the drawing, and click again to set the rotation.
Large Rivets
Rivets (DIN)
Tubular Rivets
vectorworks.net
