DesignSeries00186.pngShaft Segment Properties
To add, delete, or modify component segments to construct the desired shaft object:
  1. Select a shaft in the drawing file and click the Configuration button in the Object Info palette.
  2. While the currently selected segment is highlighted, specify the shaft segment parameters on each tab to define the shaft. Click the Update button to dynamically change the preview when changes are made.
  3. Click the Dimensions tab to specify the configuration of the shaft segment.
  5. Click the Keyway tab to specify the configuration of the shaft segment keyway (straight Segment Type only).
  7. Click the Groove tab to specify the configuration of the shaft segment groove (straight Segment Type only).
  9. Click the Wrench Flats tab to specify the configuration of the shaft segment wrench flats (straight Segment Type only).
  11. Click OK to set the shaft parameters and close the Shaft dialog box.
  12. To edit parameters, click Configuration in the Object Info palette, double-click the shaft, or select Edit from the context menu to open the Shaft dialog box. The following additional parameters can be modified directly in the Object info palette.
Shafts
Shaft Break 2
Shaft Break
vectorworks.net
