 Feature Control Frame
Feature Control FrameA feature control frame consists of a geometric characteristic symbol, up to two tolerance areas, and up to three datum reference areas.
To insert a feature control frame:
Click the Feature Control Frame tool from the Dims/Notes tool set.
Click to place the object in the drawing, and click again to set the rotation.
To add a leader and marker, click the Selection tool from the Basic palette and drag the control points on the object. Edit the marker from the Attributes palette (see Marker Attributes).
