Importing and Exporting Files
The Vectorworks program has the ability to import and export to a variety of file formats. Your work may require you to import drawings from colleagues that use previous versions of Vectorworks or other programs. You may also have to export your drawings for those colleagues. The import and export functionality provides the means to incorporate Vectorworks files with other program’s files, including other CAD programs, worksheet, and word processing programs.
Drag and Drop Importing
Importing in PartSpec Format
Importing in SketchUp Format
Importing in PICT Format
Importing a Point Cloud Object
Importing in OBJ Format (3D only)
Exporting as a Database
Exporting a Rendered Drawing
Exporting in 3D PDF Format (3D only)
Exporting in CINEMA 4D Format (3D only)
Exporting in COLLADA Format (3D only)
Exporting in FBX Format (3D only)
Exporting in KML Format
Exporting to an Earlier Version of the Vectorworks Program
Exporting in gbXML Format
Importing and Exporting in EPSF Format
Importing and Exporting Image Files
Importing and Exporting in Metafile Format
Importing and Exporting PDF
Importing and Exporting in Shapefile Format
Importing and Exporting Scripts
Importing and Exporting in 3ds Format
Importing and Exporting in IGES Format
Importing and Exporting in SAT Format
Importing and Exporting in STEP Format
Importing and Exporting in STL Format
Importing and Exporting in Rhino 3DM Format
Importing and Exporting in Parasolid X_T Format
Importing and Exporting Georeferenced Images
Importing and Exporting Vectorworks Spotlight Data
Importing and Exporting Hoist Data
DXF/DWG and DWF File Import
DXF/DWG and DWF File Export
Batch Publishing
IFC Format Interoperability
Importing Worksheets
Exporting Worksheets
vectorworks.net
