Land00004.pngInserting an Irrigation Head
A generic irrigation head can be inserted into the drawing with the Irrigation Head tool. Alternatively, use an irrigation head from one of the irrigation object libraries.
To insert an irrigation head:
  1. Click the Irrigation Head tool from the Site Planning tool set.
  2. Click to place the object in the drawing, and click again to set the rotation.
The spray pattern can be hidden and displayed with the Show or Hide Spray Pattern command (see Show/Hide Spray Pattern).
vectorworks.net
