Notes Management without Databases
Inserting Callouts or Keynotes
The Callout tool places callout objects on a drawing. A callout object is a block of text attached to a leader line with an optional bubble surrounding the text. Use callout objects to annotate items in a file.
In the Vectorworks Design Series products, the Callout tool includes extended capabilities which allow it to be used for keynotes. A keynote legend is automatically created.
A keynote can be used without a database as described in this section, or in conjunction with an external notes database (see Placing Database Callouts).
Mode
Description
Towards Target
Click first where the callout text is to be placed, and then on the object to be annotated
Towards Text
Click first on the object to be annotated, and then where the callout text is to be placed
Two Point
Two clicks are required to place the callout object; in Two Point mode, the length of the shoulder is determined in the callout preferences or Object Info palette
Three Point
Three clicks are required to place the callout object; in Three Point mode, the third click determines the length of the shoulder
Preferences
Opens the Callout Preferences dialog box
To create a callout or (for Vectorworks Design Series products) a keynote:
  1. Click the Callout tool from the Basic palette.
  2. Click the Preferences button from the Tool bar.
  3. The Callout Preferences dialog box opens. Specify the default settings for callouts or keynote objects during this session and click OK.
  4. Click OK to set the callout or keynote preferences.
  5. Click the desired insertion modes from the Tool bar, and then click in the drawing to set the insertion point of the callout or keynote object.
  6. Depending on the mode, the first click defines the leader shoulder or the leader endpoint.
  7. Click again to determine either the leader endpoint or leader shoulder, depending on the mode.
  9. If in Three Point mode, click a third time to define the shoulder length.
  10. The Notes Manager: Callout dialog box opens. Enter the callout or keynote legend text; text wraps if longer than the specified maximum text width. Press Enter to add a carriage return.
  11. Click OK.
The callout or keynote is placed in the drawing; if a keynote is placed, a keynote legend object is also created.
Editing a Callout Object
Editing Keynotes and the Keynote Legend
Formatting Text
Specifying Callout or Keynote Legend Bubble Shadow Settings
vectorworks.net
