The Add Solids command joins two or more 3D objects into a single model.
To add solids in 3D:
Select two or more 3D objects to combine.
Select Model > Add Solids.
A single solid model is created from the objects.
Editing 3D Object Surfaces
Editing 2D Object Surfaces
vectorworks.net
