Editing Object Surfaces
Editing 2D Object Surfaces
There are four commands for editing 2D and 2D/3D hybrid object surfaces: Intersect Surface, Add Surface, Combine into Surface, and Clip Surface. The Intersect, Add, and Clip commands have an equivalent context menu command accessed by a Ctrl-click (Mac) or right-click (Windows). Use these commands with the following objects.
Vectorworks Fundamentals Objects
●    2D primitive objects that can be filled and are not grouped (arcs, polygons, polylines, ovals, circles, rectangles, rounded rectangles)
●    Revision clouds
●    Floors
●    Roof faces
●    Pillars
Vectorworks Design Series Objects
●    Ceiling grids
●    Plants
●    Massing models
●    Stipples
●    Property lines
●    Redlines
●    Site modifiers
●    Seating layouts
●    Spaces
●    Hardscapes
●    Parking Areas
●    Stages
●    Slabs
These commands work in any view, as long as the objects involved are in the same plane. If a combination of 2D and 2D/3D hybrid objects (such as floors or pillars) will be used in an operation, the view must be set to Top/Plan. In Top/Plan view, screen plane and layer plane are considered to be co-planar.
The equivalent 3D commands operate on solids and can be used in a 3D view.
Intersect Surface
Add Surface
Clip Surface
Editing 3D Object Surfaces
vectorworks.net
