The Arc into Segments command converts a selected arc or circle into an equal number of segments, or divides the arc or circle into segments of a given length. The segments can be drawn as lines or polygons; the original object remains unchanged.
To convert a circle or arc into segments:
Select the arc or circle to be converted.
Select Modify > Drafting Aids > Arc into Segments. The Arc into Segments dialog box opens.
Click OK to create the segments.
