Project Setup
for Mechanical DesignAt the beginning of a mechanical design project, use the Drawing Setup command to quickly set relevant drawing units, layer scale and print area from a single dialog box. A sheet border and title block can also be inserted automatically. An alternate method of setting up a document is to open one of the pre-configured machine design template files and use it as a starting point.
The Machine Design (Imperial) template opens with File > Document Settings > Units set to inches on the General Display tab, decimal rounding set to three decimal places, and the design layer scale set at 1:1.
To set up a project with the Drawing Setup command:
Select File > New.
The Create Document dialog box opens.
Select Create blank document, and then click OK.
Select the Drawing Setup command from the appropriate menu:
● Architect workspace: AEC > Machine Design > Drawing Setup
● Landmark workspace: Landmark > Machine Design > Drawing Setup
● Spotlight workspace: Spotlight > Machine Design > Drawing Setup
The Drawing Setup dialog box opens.
Specify the drawing units, layer scale, print area, and sheet border, and then click OK. For more information on Drawing Units, Layer Scale, and the Print Area, see Setting up the Drawing.
The drawing setup parameters are saved with the file. Use the Object Info palette to make any changes to the sheet border once it has been placed in the drawing.
