Regular (Equal-sided) Polygon
Use the Regular Polygon tool to create single-line closed polygons in which all sides of the polygon are the same length. The Push/Pull mode is available in 3D views for instantly extruding the polygon after creation.
Mode
Description
Inscribed
Creates a polygon by drawing its radius to a corner
Circumscribed
Creates a polygon by drawing a radius to the mid-point of a side
Edge
Creates a polygon by drawing one of its sides
Push/Pull (3D views only)
After the polygon is created, click the selected polygon and drag to extrude it
Number of Sides
Sets how many sides the polygon has (from 3 to 4000)
Press and hold the Option (Mac) or Ctrl (Windows) key while drawing to toggle between circumscribed and inscribed modes.
Regular Polygon by Inscription
To create a regular polygon by inscription:
  1. Click the Regular Polygon tool from the Basic palette and click Inscribed from the Tool bar.
  2. Enter the Number of Sides for the polygon (a number from 3 to 4000).
  3. Click to set the center of the polygon.
  4. Click to set the corner radius.
Regular Polygon by Circumscription
To create a regular polygon by circumscription:
  1. Click the Regular Polygon tool from the Basic palette and click Circumscribed from the Tool bar.
  4. Click to set the edge radius.
Regular Polygon by Edge
To create a regular polygon by edge:
  1. Click the Regular Polygon tool from the Basic palette and click Edge from the Tool bar.
  3. Click to set a corner of the polygon.
  4. Click to set an adjacent corner of the polygon and define an edge.
2D Polygon Tool
Double-Line Polygon Tool
Creating Extruded Polygons
Push/Pull Mode of Planar Tools
Displaying and Reversing Object Direction
vectorworks.net
