3D Power Pack Cursors
Special cursors display during certain operations to help determine the current mouse function; they do not display when an active selection is about to occur.
Cursor/Operation
Where Used
Edge Selection
Extract tool’s Point and Curve modes, Chamfer Edge tool, and the Fillet Edge tool
Face Selection
Extract tool’s Surface modes, Shell Solid tool, Push/Pull tool, as well as the Chamfer Edge and Fillet Edge tools with the Select Faces option turned on.
Press the Alt key (Windows) or Option key (Mac) to select the back faces of solid objects.
Curve Selection
Loft Surface tool, Project tool, and Push/Pull tool
Surface Selection
Project tool
NURBS Curves and Surfaces
Selecting the Edges and Faces of a Solid
Displaying Surface Normals
Displaying and Reversing Object Direction
Editing a Fillet/Chamfer or Shell Object
Surface Geometry Requirements
Converting to NURBS
vectorworks.net
