Creating a Massing ModelThe Massing Model tool creates a building shell for illustrative purposes. This is an easy way to create a representative or context building when a detailed building is not required. Building models can also be created by drawing a polyline and then selecting the Create Objects from Shapes command (see Creating Objects from Shapes). A massing model can be a site modifier.
To create a massing model:
Click the Massing Model tool from the Site Planning tool set.
Click to begin drawing the outline of the building. Continue clicking to draw the shell polyline. Double-click, or click once at the start point, to end the polyline.
The massing model parameters can be edited from the Object Info palette.
If the massing model is used as a site modifier, the proposed site model requires updating. Select the site model and click Update from the Object Info palette.
Click here for a video tip about this topic (Internet access required).
