DesignSeries.pngCalculating Grade for a Site Model
The Grade tool is available in all Vectorworks Design Series products, but its site model functionality requires additional features that are available only in the Landmark product. For information on creating solid sections from grade objects, see Creating a Solid Section from Grade Objects.
The Grade tool is in the Site Planning tool set (Designer and Landmark workspaces) and the Building Shell tool set (Architect and Spotlight workspaces).
When used for site planning, the Grade tool annotates terrain slopes on site plan documents.
Networks of grade objects can be created to show slope characteristics across a surface. Grade objects can be used in conjunction with a site model, and can modify the site model. In addition, 3D loci can be generated from grade object elevations, and used as the basis of creating a site model.
The Grade tool has three modes:
Mode
Description
Insert
Draws a grade object based on set elevation parameters or a site model
Edit Elevation
Changes the elevation value of one or more existing grade objects
Update
Updates all grade objects in the drawing, applying current preference settings and updating any overlapped elevation points
Preferences
Sets the default global preferences for the grade object
Specifying Global Grade Object Preferences
Inserting Grade Objects
Editing Elevation
Analyzing Grade
Creating Loci from a Grade Object
vectorworks.net
