If the elevation changes after one or more grade objects have been placed, there is no need to replace the existing grade objects. Change the elevation of one end of a grade object, or offset the elevation of selected (or all) grade objects in the drawing.
Elevation marker symbols must be at a valid scale to edit elevations. If the Edit Elevation dialog box does not open, increase the marker scale factor for the grade object.
To edit grade object elevation:
Click the Grade tool from the appropriate tool set:
● Designer and Landmark workspace: Site Planning tool set
● Architect and Spotlight workspace: Building Shell tool set
Select Edit Elevation mode from the Tool bar.
Click at the start or end of a grade object.
On the Edit Elevation dialog box, edit the grade.
Click OK to edit the elevation of the grade object.
