The Fundamentals workspace contains various palettes for creating and editing objects. Basic and Tool Sets are tool palettes, which have special functionality, as described in Tool Palette Features. If a keyboard shortcut is currently assigned to a menu command or tool, the shortcut displays when the cursor hovers over the command or tool; to set up or modify keyboard shortcuts, see Modifying Menus and Commands.
Depending on the initial settings, some palettes may be hidden when the program is launched.
Palette / Tool Set |
Purpose |
Snapping |
Contains SmartCursor snapping controls that can be toggled on or off; see Setting Snapping Parameters |
Attributes |
Contains a selection of colors, fills, pens, and other object attributes; see The Attributes Palette |
Object Info |
Lists context-sensitive object information for viewing and editing; see The Object Info Palette |
Working Planes |
Contains controls for adding and modifying working planes; see The Working Planes Palette |
Resource Browser |
Accesses the resources available for use in drawings, including gradient fills, hatch patterns, image fills, record formats, scripts and script palettes, symbols and symbol folders, worksheets, textures, backgrounds, and more. See Using the Resource Browser. |
Navigation |
Provides access to classes, design layers, sheet layers, viewports, and saved views, while the drawing area remains accessible; see The Navigation Palette |
Visualization (Renderworks required) |
Accesses all lights and cameras in the file; see Managing Lights and Cameras with the Visualization Palette |
Contains a single set of basic object creation and editing tools; the palette can be customized through the Workspace Editor |
Depending on the workspace, the palette includes the following tool sets, whose tools are grouped by similar functionality; the palette and its tool sets can be customized through the Workspace Editor. Each tool set may contain different tools in different workspaces. |
Site Planning |
Contains tools for site planning and landscape architecture |
Space Planning |
Contains tools for space planning and programming buildings |
Spotlight |
Contains tools for lighting and entertainment facility design |
Building Shell |
Contains tools for creating building shell elements |
3D Modeling |
Contains tools for creating and editing 3D objects, including solids and NURBS |
Visualization |
Contains tools for changing the drawing view in different ways, including the Walkthrough and Light tools |
Furn/Fixtures |
Contains tools for creating common furniture and fixtures |
Dims / Notes |
Contains tools for adding dimension and label objects |
Walls |
Contains basic wall creation tools |
Detailing |
Contains tools for adding architectural detail objects, such as tubing |
MEP |
Contains tools for mechanical, electrical, and plumbing design |
Fasteners |
Contains tools for inserting a variety of fasteners such as nuts, bolts, pins, and screws |
Machine Components |
Contains tools for inserting machine components such as gears, bearings, and springs |
Script Palettes |
Contains palettes with script resources |
