A record format’s fields and default values can be edited from the Resource Browser.
To edit record format values:
From the Resource Browser, select the record format.
Select Edit from the Resources menu.
The Edit Record Format dialog box opens.
Select the record format field to edit and click Edit to change the default value, or click New or Remove to add or delete fields.
Click OK.
The edits do not affect existing values for attached records. Changes are applied to the default field values when attached to symbols or objects, or for future symbols with the record attached.
