Editing Record Formats
Record formats can be edited in a variety of ways, depending on the desired outcome.
Method
Result
Edit the record format resource, changing the field list and/or default field values (see Editing Default Record Formats)
Future objects or symbols with the record attached reflect the changes; existing attached records are unaffected
Edit the field values of a record attached to a selected object (see Viewing and Editing Object Records)
Changes to field values affect the selected object only; the record fields cannot be changed. Existing and future objects with the record attached use the default values.
Edit the record field values of a symbol definition (see Editing Symbol Default Record Values)
Changes to field values affect future instances of the symbol. Existing symbols, other symbols with the record attached, and the record format resource are unaffected.
Alternatively, make global changes with the symbol utilities (see Changing One Record Format Field and Changing All Record Format Fields).
Creating Record Formats
Splitting and Merging Record Formats
Linking Text to Record Formats
Database Connectivity
vectorworks.net
