Renderworks00093.pngReflectivity Shaders
Shader
Description
Specifies an imported image to be used as the reflectivity shader (white is more reflective; black is less reflective); see Creating Image-based Shaders
Backlit
This shader is useful for lamp shades, light bulbs, and curtains that are lit from behind. If Cast Shadows is selected in the Edit Texture dialog box, the backlit shader acts as an area light for indirect lighting. If Cast Shadows is not selected, the backlit shader does not emit light.
Color
Specifies a color to be applied as a backlit color; click the color box to select the color
Brightness (%)
Controls the backlit brightness
Reflection (%)
Sets the amount of reflection to use, or set to 0 for no reflection
Blurriness (%)
Sets the amount of blurriness for the reflection, or set to 0 for no blur
Glass
Edge Color
Click the color box to set the color applied to the glass at an angle, which is seen at the edge of the glass
Center Color
Click the color box to set the color at the center (main) part of the glass
Blurriness (%)
Glow
The glow shader offers an alternative to creating line or area lights, and can create “neon” signs
Brightness (%)
Sets the amount of glow
Emit Light
Allows the texture to become a light source, when Indirect Lighting is enabled (View > Set Lighting Options)
Add Matte Reflectivity
Creates a partially glowing light that is also lit by other light sources
Reflection (%)
Blurriness (%)
Metallic
Creates metallic effects (also try colored mirror shaders for polished metal effects).
Metallic effects require the presence of light objects in the drawing. Panoramic image background lighting will not produce metallic effects.
Color
Click the color box to select the metallic color
Pattern
Select the type of metallic pattern
●    Metallic: provides a metallic paint effect (such as for car bodies)
●    Brushed: provides a brushed metal appearance
●    Turned: creates a machine-turned round pattern
Reflection (%)
Blurriness (%)
Mirror
Color
Click the color box to select the mirror color; use grayscale for a regular mirror effect, and select colors for mirrored metallic effects
Reflection (%)
Blurriness (%)
Sets the amount of blurriness for the reflection; using a non-grayscale color and some blurriness creates an effective metallic look
Plastic
Color
Click the color box to select the plastic color
Brightness (%)
Sets how bright the shader appears
Roughness (%)
Sets the width of shiny areas on the plastic; increase the percentage for wider shiny areas
Reflection (%)
Blurriness (%)
Bricks
These parameters are the same for all shaders; for a description, see Color Shaders
Noise
Pavement
Tiles
Color Shaders
Transparency Shaders
Bump Shaders
Creating and Mapping Textures
vectorworks.net
