Renderworks00094.pngTransparency Shaders
Shader
Description
Image Mask
Selects an imported image to apply as a transparency mask (see Creating Image-based Shaders)
Selects an imported image to apply as a transparency texture (see Creating Image-based Shaders), for colored transparency and projected colored lights like gobo projections in the Vectorworks Spotlight software
Color
Specifies a color to be applied as a transparency
Color
Click the color box to select the transparency color
Brightness (%)
Lightens or darkens the selected color
Glass
When using glass transparency, set the accompanying color shader to a dark color (or even black) for best results
Transmission (%)
Sets how much light passes through the glass; set to a high value when the glass is very clear
Index of Refraction
As light moves through a medium, the index measures the change in the direction of the light’s rays. An index of 1.0 indicates no change; a typical value for water and ice is 1.3, and for glass use 1.5 – 1.6.
To save time, use a value of 1.0x (just above 1) when the glass is thin.
Color
Click the color box to select the color that appears in a very thin object; for glass, this is usually set to white
Blurriness (%)
Blurs the transparency by the specified amount, or set to 0 for no blur. Blurred glass appears frosted (and takes longer to render).
Absorption Color
Click the color box to select the color that a large, thick object assumes, when a ray of light has traveled the Absorption Distance
Absorption Distance
Defines the distance rays of light have to travel before Absorption Color replaces Color. The lower the value, the more intense the Absorption Color is. This applies to thick or thin glass.
Plain
Provides plain, uniform transparency of a specified amount
Opacity (%)
Sets how opaque the shader is; set to a lower value for more transparency and to a higher value for more opacity
Rectangular Mask
Uses the texture as a rectangular mask to apply as a transparent texture (usually combined with another shader to create a specific masking effect). Useful for decals.
Horizontal/Vertical Repetitions
Indicates how to display the mask: a single instance, infinite repetitions, or a set number of repetitions in each direction
Bricks
These parameters are the same for all shaders; for a description, see Color Shaders
Noise
Pavement
Tiles
Color Shaders
Reflectivity Shaders
Bump Shaders
Creating and Mapping Textures
vectorworks.net
