DesignSeries00086.pngCreating Wall Recesses
To create a wall recess:
  1. Create the closed 2D or 3D solid object with which to modify the wall. The geometry of the object must define an area or volume that has no self-contacts, no self-intersections, and no edges that fold back on themselves.
  2. For a 2D object, simply make sure that the object overlaps the wall in Top/Plan view. For a 3D object, first create the object at the appropriate height in relation to the bottom of the wall (Z axis); then set the appropriate X and Y axis location so that the object overlaps the wall.
  3. With both the appropriate wall and the modifier object selected, choose the Create Wall Recess command from the appropriate menu:
  4. ●    Architect workspace: AEC > Create Wall Recess
    ●    Landmark workspace: Landmark > Architectural > Create Wall Recess
    ●    Spotlight workspace: Spotlight > Architectural > Create Wall Recess
    Alternatively, for 2D objects only, select Modify > Clip Surface.
    The Create Wall Feature Recess dialog box opens; different fields display depending on whether a 2D or 3D modifier object is selected.
  5. Select the options for the wall feature, and click OK.
Creating Wall Projections
Wall Feature Properties
Editing Wall Features
Creating Wall Features
Creating Walls
vectorworks.net
