Reshaping Walls
Use the Reshape tool in a 3D view to edit the wall height, change the elevation of wall peaks, add vertices to create peaks in a wall, and delete vertices that have been added. Use the Selection tool to change the wall length. Symbols remain where placed when a wall is reshaped.
In the following situations, the Reshape tool displays 2D Reshape modes; the vertices at either end of the wall can be moved, to change the wall length and/or location. See 2D Reshape Modes.
●    In Top/Plan view
●    When multiple walls are selected
●    When a wall and other objects are selected
●    When a marquee has been drawn
In any 3D view, when only a single wall is selected, the Reshape tool has three modes available.
Mode
Description
Reshape 3D Walls
Adjusts the position of a selected wall vertex
Add 3D Wall Peaks
Adds a vertex to a wall for reshaping purposes
Delete 3D Wall Peaks
Deletes a wall vertex
Walls can also be trimmed using the Trim tool; see Trim Tool.
Changing Wall Length
Changing Wall Height
Changing Wall Peak Height
Adding a Vertex to Walls
Deleting a Wall Vertex
Reshaping Objects
Changing Round Wall Radius
Removing Wall Breaks
Joining Walls
Joining Walls with the Fillet Tool
Inserting and Editing Symbols Within a Wall
Creating Walls
vectorworks.net
