Creating Reference Markers
Use the Reference Marker tool to indicate the drawing number and sheet number of a referenced drawing, in a variety of configurations.
Reference markers maintain a constant size regardless of the drawing scale.
To create a reference marker:
  1. Click the Reference Marker tool from the Dims/Notes tool set.
  2. Click to place the object in the drawing, and click again to set the rotation.
Using Notation Objects
The Attributes Palette
Formatting Text
Using Text Styles
vectorworks.net
