Creating Revision Markers Use the Revision Marker tool to indicate the drawing revision number.
Revision markers maintain a constant size regardless of the drawing scale.
To create a revision marker:
Click the Revision Marker tool from the Dims/Notes tool set.
Click to place the object in the drawing, and click again to set the rotation.
