Menu Command
Description
Location of the Data bar fields
Use floating Data bar
The Data bar floats with the cursor in the drawing area
Use floating Data bar only when tab key is pressed
The Data bar floats with the cursor only when the Tab key is pressed; otherwise the bar does not display
Do not use floating data bar - show data bar fields on fixed data bar
The Data bar displays on the top left side of the window, at the top of the Tool bar
Activation of the Data bar
Allow numeric keypad entry for instant Data bar activation
When the floating Data bar is displayed, enter numbers on the keyboard or numeric keypad to activate the first field
Do not allow numeric keypad entry for instant Data bar activation
When the floating Data bar is displayed, enter numbers on the keyboard only to activate the first field
Do not allow instant Data bar activation
When the floating Data bar is displayed, press the Tab key to activate the first field
Field display on the Data bar
Show only primary fields on Data bar
Show only the primary data fields (for example, L and A for circles)
Show primary and secondary fields on data bar
Show all fields except the cursor location fields (X and Y)
Show primary, secondary, and cursor location fields on data bar
Show all fields
Field cycling options
Auto cycle to non-displayed fields when tabbing past last field
When some of the data fields are hidden, press the Tab key in the last visible field to make the non-displayed fields become visible
Do not auto cycle to non-displayed fields when tabbing past last field
When some of the data fields are hidden, press the Tab key in the last visible field to return to the first field
Location of the floating Data bar
Show floating Data bar below SmartCursor cues
When the floating Data bar is enabled, displays the Data bar below the SmartCursor cues (below the cursor)
Show floating Data bar above SmartCursor cues
When the floating Data bar is enabled, displays the Data bar above the SmartCursor cues (above the cursor)
Data bar activation on datum creation
Show floating Data bar after datum creation
When the floating Data bar is enabled, displays the Data bar automatically after a datum is set
Do not show floating Data bar after datum creation
The floating Data bar does not automatically display after a datum is set. Press the Tab key to display the floating Data bar.
Display of the Exit Group button
Use large exit group button
When a group is being edited, show a large button with the label Exit Group in the upper right corner of the drawing area
Use small exit group button
When a group is being edited, show a small button with an arrow icon in the upper right corner of the drawing area
Exit group options
<Esc><Esc> exits group
When a group is being edited, pressing the Escape key twice exits the editing window
<Esc><Esc> does not exit group
When a group is being edited, pressing the Escape key twice does not exit the editing window
