Diametrical Dimensioning Outside Circle/Arc
The External Diametrical mode measures and dimensions the diameter of a circle or arc, and places the dimension outside the object.
To create a diameter dimension outside of a circle or arc:
  1. Click the Radial Dimension tool from the appropriate tool set/palette, and select External Diametrical mode.
  2.     All workspaces: Dims/Notes tool set
        Spotlight and Landmark workspaces: Basic tool palette
  3. From the Tool bar, select a Dim Std (dimension standard).
  4. From the Tool bar, specify where to place the measurement.
  5. To place it to the right of the leader line, click Right-Hand Shoulder mode. To place it to the left of the line, click Left-Hand Shoulder mode.
  6. Click on or within the arc or circle to dimension.
  7. Move the cursor to preview the dimension line location.
  8. Click to place the dimension.
Radial Dimensioning
Editing Dimensions
vectorworks.net
