Editing Dimension Properties
Edit the properties of one or more selected dimensions in the Object Info palette. Alternatively, right-click (Windows) or Ctrl-click (Mac) on the dimension, and select Properties from the context menu.
For chain dimension objects, the edits are applied to all dimensions within the chain. To edit the properties of individual dimensions within a chain, right-click (Windows) or Ctrl-click (Mac) on the dimension, and select Edit Dimension from the context menu instead.
Different parameters are available depending on what type of dimension is being edited.
Editing Dimensions
vectorworks.net
