Spot00023.pngInserting a Curved Truss
Curved truss parameters are illustrated by the following diagram.
To add a curved truss to the light plot:
  1. Click the Curved Truss tool from the appropriate tool set:
  2. ●    Spotlight workspace: Spotlight tool set
    ●    Designer workspace: Detailing tool set
  3. Click to define the truss insertion point. Click again to set the rotation of the curved truss.
Trusses are 2D/3D hybrid objects. Complex trusses can increase the time required to render the model in 3D.
If the final segment of a truss is shorter than the defined interval length, it is displayed in red when Highlight is selected.
To use the truss as a lighting position, convert it to a lighting position object; see Creating a Lighting Position Object.
Rotating a Curved Truss
A curved truss can be rotated with the Rotate tool.
To rotate a curved truss:
  1. Select the truss. In the Object Info palette, select Draw 3D Only.
  2. Click the Rotate tool from the Basic palette.
  3. Click to set a fulcrum line; click to end. Move the cursor to rotate the truss, and then click to set the rotation.
Inserting a Straight Truss
Truss Configuration Requirements
Replacing Stage Decks and Trusses with Symbols
Inserting Lighting Positions
Creating Lighting Positions
vectorworks.net
