Spot00016.pngInserting a Straight Truss
Straight truss parameters are illustrated by the following diagram.
To add a straight truss to the light plot:
  1. Click the Straight Truss tool from the appropriate tool set.
  2. ●    Spotlight workspace: Spotlight tool set
    ●    Designer workspace: Detailing tool set
  3. Click to place the object in the drawing, and click again to set the length and rotation.
Trusses are 2D/3D hybrid objects. Complex trusses can increase the time required to render the model in 3D.
A connection interval shorter than the defined interval length is displayed in red when Highlight is selected.
To use the truss as a lighting position, convert it to a lighting position object; see Creating a Lighting Position Object.
Inserting a Curved Truss
Truss Configuration Requirements
Replacing Stage Decks and Trusses with Symbols
Inserting Lighting Positions
Creating Lighting Positions
vectorworks.net
