Placing Lighting
Pipe ObjectsInsert and configure a lighting pipe object with the Lighting Pipe tool.
To insert a lighting pipe object:
Click the Lighting Pipe tool from the Spotlight tool set.
Alternatively, create a polyline and then select the Create Objects from Shapes command (see Creating Objects from Shapes).
Click in the drawing area to begin drawing the lighting pipe.
To draw a multi-segment pipe, click to set the end of one segment and start the next.
Create a curved pipe by changing the vertex type (see Creating Polylines).
Double-click to complete the lighting pipe polyline.
To use the lighting pipe as a lighting position, convert it to a lighting position object; see Creating a Lighting Position Object.
