Land00117.pngPlacing Station Points Along the Road Polyline
The Vectorworks Landmark product places station points (stake objects) along the selected polyline at a specified interval.
To place station points:
  1. Select the polyline, and then select the Station on Polyline command from the appropriate menu:
  2.     Designer workspace: AEC > Roads > Station on Polyline
        Landmark workspace: Landmark > Roads > Station on Polyline
  3. The Place Station Points Along Polyline dialog box opens. This command places stations at 100’ (or 30.48 m) intervals. In addition, partial station points can be placed at smaller intervals. Enter the interval between partial stations and select a labeling option for the curve information.
  4. Click OK to create the station points along the polyline.
  5. The first time you use the command in a file, a properties dialog box opens. Set the default properties, and click OK. The properties can be edited from the Object Info palette. Stake properties are described in Inserting Stake Objects.
    Each station point is labeled. If curve data tables were created, they can be selected and moved if necessary.
  6. The stakes have all been set to the elevation of the site model; the next step is to automatically set the road stake elevations as described in Setting Stake Elevations .
Creating the Road Centerline
Creating the Road
vectorworks.net
